General
Pondremos nuestras listas de chequeo, para compartirlas y mejorarlas si fuese necesario.
Moderadores: fjgarbar, jpmasso, jlf, XAIR, hm1000, carlomax
General
#1 Mensaje por ARIAS » Mar Sep 29, 2009 18:02
Preflight Inspection
Interior
Hobbs and Tach CHECKED
Weight and Balance IN LIMITS
Parking Brake SET
Control Lock REMOVE
Battery ON
Boost Pump VERIFY
Beacon Light OPERATIONAL
Landing Light OPERATIONAL
Battery OFF
Exterior
Wings
Flaps INSPECT
Ailerons INSPECT
Wingtip and Lights INSPECT
Pitot Cover REMOVE
Pitot Tube CLEAR
Stall Warning Horn OPERATIONAL
Fuel Vent CLEAR
Fuel Condition WATER-FREE
Fuel Condition CONTAMINANT-FREE
Fuel Quantity VISUALLY INSPECT
Fuel Cap SECURE
Landing Gear INSPECT
Tiedowns REMOVE
Chocks REMOVE
Engine
Engine Condition VISUALLY INSPECT
Oil Level INSPECT
Oil Dipstick / Door SECURE
Alternator Belt TIGHT
Carburetor Inlet CLEAR OF DEBRIS
Spinner SECURE
Empennage
Static Port CLEAR
Baggage Door SECURE
After Engine Start
Toe Brakes TEST
Throttle 1000 RPM
Run Up
Throttle 2000 RPM
Magnetos CHECK
Carburetor Heat CHECK
Gyro Suction IN LIMITS
Throttle IDLE
Flight Instruments SET and CORRECT
Engine Instruments SET and CORRECT
Before Takeoff
Flight Controls FREE AND CORRECT
Flaps TAKEOFF
Cabin Doors CLOSED AND LOCKED
Cabin Windows SECURED
Transponder ON/ALTITUDE
Fuel Selector OPPOSITE TANK
Elevator Trim TAKEOFF
Emergency Procedures - Engine Failure
Ignition/Magnetos ENGAGED
Volver a “Listas Chequeo - Check List”
