Jabiru J200/J400 en Inglés
Pondremos nuestras listas de chequeo, para compartirlas y mejorarlas si fuese necesario.
#1 Mensaje por ARIAS » Mar Sep 29, 2009 17:19
Before Every Flight
Read Local Rules
Check Weather
Briefing Notices
Check Booking Sheets
Sign Autho Sheet
Take Headset, and Fuel Strainer
Before Start
Pre-flight
Doors
Seats
Harness
Headset
(Top to Bottom, Left To Right)
Electrics
Ignition
Flaps
Fuel
Throttle
Prop Pitch
Mixture
Alt air
Throttle friction
Primer
Brakes
Start Checks
Call clear
Look Out
Engine Start
After Start
(ROAMIRS)
Rpm
Oil
Alt air
Mixture
Instruments
Radios
Security
Taxi Checks
Brakes
Instruments
Before Take-off
PARK PLANE INTO WIND
Brakes
Prop Blast
Fuel
Mixture
Services
Checked
Checked
Checked
Checked
Checked
Checked
Inspection Complete
Closed
Locked in Pos.
Tight
Plugged In
Scan
Avionics off, rotating beacon on,
Master on, circuit breakers in.
Key pos. at off
Retracted
Fuel Pump on 6 sec/On
Open 1-2 cm
(Not applicable)
Full Mixture
Set to QNH
Finger Tight
Prime a Few Times/out
Applied
Prop clear
Make sure prop clear
Start engine
1200 rpm
Oil press. Read in 30 seconds
Set to QNH
Mixture full, magnetos on
L-R T-B
Selected on, correct freq.
Harness, brakes working
Test
1.Compass (L-decreas R-increase)
2.A/H Stable
3.D.I. (Same as Compass)
4.Turn left, ball to the right. Turn right, ball to the left.
5.Turn left, wings left, turn right, wings right
6.ADF tracking
7.Temps. & Press. In green
8.Fuel check
Set, Park Brake
Check Behind
Select fullest main tank/both/contents
Fully rich
Check all instruments
Engine Run Up
Throttle
D.I.
Suction
Temps. and press.
Mixture
Prop Pitch
Carburettor heat
Magnetos
Throttle
Pre Take Off
(To Many Co-Pilots Go Fly in Heaven Early)
Test Controls
Throttle and friction
Trim
Master
Mixture
Magnetos
Prop pitch
Primer
Pressures and temps.
Gills
Gyros
Fuel
Flaps
Instruments
Harness
Hatches
Electrics
Take-Off Briefing
Review Speeds
Abort procedure
Engine failure
Departure Clearance
Call “Ready”
Strobes and Transponder
Landing light
Line up Checks
(When do flaps retract)
Windsock
DI aligned
Flaps
Reference point
After Take-Off
300’ AGL
Brakes
Undercarriage
500’ AGL
Brakes
Undercarriage
Power
Pitch
Mixture
Fuel
Flaps
Instruments
Electrics
Run Up RPM
Set To Compass
Check 4-6
Normal
Check till drop and back
Cycled
Check (Not more than 1.75)
One by one, Off and On
Full back, and the 1200-rpm
Correct and free movement
Idle and finger tight
For Take
On
Fully Rich
Both On
Fully Fine
In And Locked
All In green and in limits
Check Instruments
Check Instruments
Fuel pump on, fuel pressure
Set for take-off
Top to Bottom, left to Right
Tight and secured
Closed and locked
Check radio and lights
Rotate, Climb and best glide
Sufficient runway remaining
Insufficient runway, SFFF
Obtain and review
No A/C on finals
S-On, T-Alt when cleared on runway
On when cleared for take-off
Stick into wind
Aligned with r/w heading
Set for take-off
Pick on end off runway
Apply to stop wheels
Retract
Apply
Confirm up and locked
Set for climb
Set for climb
Set for climb
Fuel pump off, contents and selection
Retract
Check services and speeds
Landing and strobes off
Pre-Manoeuvring Checks
(Hasell)
Height
Airframe
Security
Engine
Location
Look out
TOC, TOD & Field APP checks
(FREDAAS)
Fuel
Radios
Engine
D.I.
Security
Downwind Checks
Brakes
Undercarriage
Mixture
Prop Pitch
Power
Fuel
Flaps
Instruments
Electrics
Base Leg Checks
Carbheat
Power
Flaps
Final APP Checks
(CUFFT)
Carbheat
Undercaraige
Fuel
Flaps
Trim
After Landing Checks
Flaps
Fuel Pump
Landing Light
Strobes
Mixture
Transponder
Shut Down Checks
Brakes
Avionics
Magnetos
Mixture
Throttle
Magnetos
Beacon
Master
Aircraft
2000’ AGL after recovery
Flaps, landing gear, brakes of, trim
Hatches and Harnesses
Fuel cont. and pump on, mix. & Carb
Contr. airspaces, towns, aerodroms etc.
360* inspection turn
Contents, selection
Correct freq.
Temp. and Press. (Nav. Carbheat)
Set to compass
Harnesses, doors, etc.
Check for brake pressure
Down
Fully rich
Set for climb
As required
Fuel pump on, selection
As Required
Check Temps. And Press.
Landing lights and strobes
On below 2000rpm
As Required
As Required
Off
Down and locked
Fuel pump and, contents
As required
Constant ROD
Retracted
Off
Off
Off
Lean for Taxi
Standby
On
Off
Dead-cut check
Full back
Closed
Off
Off
Off
Secured
Engine Failure
(SFFF)
Speed
Field
Fault
Flaps
Engine Fire
Engine Shutdown
Cabin Vent
Extinguish fire
Mayday Call
Land ASAP
65 Knots
30* inside heading
Find Fault
Full
All Off
Closed
Use it
Inform tower
Bad luck!!!
http://freechecklists.net/getDoc.asp?fp ... cklist.doc
Volver a “Listas Chequeo - Check List”
